RE: Why wont my Kaos spin right
HI,
You didn't say which Kaos you are flying. Sixties or forties. For the .60 engines there is a most noticeable effect caused by engine side (right ) thrust. Note that more power and same side thrust means more tendency to that side. If you underscored the amount as per drawings to the right your plane will be harder to spin to the right than to the left. If you feel your plane have a light tendency to fly to the left that's the point. So I suggest you to check the side thrust angle and correct it as necessary. If you already have everything checked say same amount of ailerons and rudder for both sides, wing is free of warps, no differential travel for ailerons, side thrust etc etc; you can trial increment by 1 degree your engine right thrust . Hope this can help you.
IGOS R/C
