RE: Myrtle Corey
Doc
The push/pull system on this boat is very difficult (if even possibel) to get the "clunk, clunk" out of! It hesitates at top/bottom dead center and is a "pain". You'll be going with the pulley/belt system if you want a smooth running wheel! If your building it to sit on the "mantel" fine, but if it's for fun and to run in the water, go with pulley/belt system!
Also...the Texas House on the top roof makes the boat top heavy and it will tip over very easy. So be watchful for that!!!!!
ISR
