RE: The GTP Thread
Tried the losi HT pipe today. Paired with the lrp it was good off the line, fell kinda flat in the midrange, then picked up again on top. So far I like the jp2 the best. Kinda weak on the very bottom, but mid and top are much better. It seems as though the picco 28 is gonna be the way to go though, with o86 pipe. Now playing with adjusting the rear control arms. I would lllike to reduce the body roll, and reduce camber gain in the rear. I have to run about 1degree +camber or the tires wear to much to the inside. Same with the fronts, but not much adjustments to be made there. Also need some stronger springs all around. Any ideas? Later.
