RE: Help with older engine
The Brat carbs were not the best. The NV's were made of brittle metal. You might want to disassemble yours and check the internal casting. My Brat .25 had a whole bunch of flash covering up the lower openings of the bypasses (correct term?). After filing all of the flash off and installing a Magnum carb it's a great running engine. It is also very light because mine is AAC.
David
