RCU Forums - View Single Post - Fuel Ratios
Thread: Fuel Ratios
Old 08-03-2008 | 08:17 AM
FlyerRick's Avatar
FlyerRick
Default RE: Fuel Ratios
Thanks for your reply Andy. Now is that for all CoolPower Blends or fuel blends in general? I know in the lubricant end of things some manufactures use Castor and some use Synthetics?
Example: CoolPower 20% Heli (Pink) is 20% Nitro, 20% Lubricant (Synthetic) (Ultra-High Viscosity)
, and 60% Alcohol...is that right?
With this in mind... how about the CoolPower Pro-Pattern 20% blend? Which is also 20% Nitro, 20% Lubricant (Ultra-High Viscosity)? Is the rest of that blend Alcohol also. I had herd before that the remainder of the fuel percentage (60%) was Methanol or Methyl alcohol???
I appreciate you help here Andy. I have been all over the forums looking for an answer to these questions but no one can give me an absolute answer that...yes this is how blends break down in percentages.
