RE: Engine for 4*
n19ht: Covering question...Does the 4* come with those white bands on the bottom of the wing or did you add those?
WMB: Let me know how the OS55AX works out as that is what I was told to use...what prop will you run on it?
I checked the weight and it has less weight than the Tower Trainer which I currently have and that runs on a TH46ABC and it can almost hover...
