I usually trim it my self but something was wrong with the trimmings because they were WAY off so I wanted to trim it right and bring it down. I mistakenly asked someone to do the trim while I handled the sticks. It did not cross my mind even the SLIGHTEST bit that a 30 year veteran will do this considering he also flies a DX7 on mode 2.
anyways, the Fuse is fixed.
. Only the wing is left. I am planning on stripping it all down and using a different design on the trimmings.
I still need some advice on how to fix the rib sparts... the front is broke, do I need ALL new ribs? That's a lottt of work if I need to make the wing from scratch.
