RCU Forums - View Single Post - Phoenix Model Extra 330 Terrible ARF!
Old 08-08-2008 | 09:30 AM
chuck993
Default RE: Phoenix Model Extra 330 Terrible ARF!
I'm hoping it flies good, I am taking my time to fix stuff as I go in hopes that it will fly well... the wing tube didn't fit in the wing, so I had to sand the inside of the wing...the wing tube was too long, so I had to cut it in order not to damage the other wing when installing the wings on the fuse... obviously this was never test fit, 2 out of 4 of the motor mount blind nuts came out of the wood during the install, they were barely in the wood came out immediately, brace across top of fuse was weak and cracked, installed an O.S. 91 FS at the recommended distance and the engine mounts are blocking the throttle, so it cannot turn the throttle, I have to grind down the motor mount for clearance, that's just off the top of my head. The manual is a joke...
This is the worse ARF I have ever seen[>:]...I've had several Seagulls, much better made, serval Hangar 9s...much better made...I will NEVER buy another Phoenix, now I know why they are so cheap...LOL
