Thanks for the tips
burned 3 tanks, on and off, playing with different setups, trail and error. Nothing helped to unload the extra "wet ride" that engine had to push.
But tips regarding the prop setup, trims helped to keep it more solid on water.
I never had a chance to see how fast it could go: The hull was pulling hard to RIGHT at around 3/4 of throttle.Beefy servo? should i move the rudder farther pass the prop line?
I tried two of my only props and both were pushing the hull 100% better with this engine than fuji.
Any more tips on the ruder setup or any comments i would really appreciate!
Thank you
Dan
Im little scare to run this thing , the way it leans, and the fact it not planing so well .... i guess its the design thing
