RCU Forums - View Single Post - Midwest Citabria - Build Thread
Old 08-10-2008 | 05:38 AM
  #43
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Midwest Citabria - Build Thread
Started looking at a rear gear mount. I'm building this plane to go float flying in early October. Had to add a plywood plate and some blind nuts. Did the same as the other blind nuts. Drill a pilot hole and leave the bit in place. Shove bolts in the larger holes to keep it all lined up while you drill the other holes.
Added the lite ply tail wheel doubler. Added some belly formers on the fuse. Going to work on cutting a new former to place in front of the rear gear.
ID:	1007888   Click image for larger version
ID:	1007889   Click image for larger version
ID:	1007890   Click image for larger version
ID:	1007891   Click image for larger version
ID:	1007892   Click image for larger version
ID:	1007893   Click image for larger version
ID:	1007894   Click image for larger version
ID:	1007896   Click image for larger version
ID:	1007897   Click image for larger version
ID:	1007898   Click image for larger version
