RCU Forums - View Single Post - Hangar 9 F-22 Raptor PTS
Old 08-12-2008 | 04:51 PM
  #546
RU4JESUS2 FALCONGTS
Default RE: Hangar 9 F-22 Raptor PTS
the shims go on the bottom 2 bolts only sorry for bad pic look at the first pic and see how the motor mount is
i just used brass washers what i had i think the guys said around 3mm total you can use any washers just watch the weight and go in small steps (washers) i added 2 per bolt
the spinner i just got a normal 2 blade spinner ill need to see what size for you
did the shims at the club was easy and did not have to ck the cg and i think i only added 1 or 2 clicks of trim elevator may have been me (pilot error)
i need to take a pic of my nose inside i never added the plywood braces did a quick fix at the field one day and its held up so far
had about 8 flights with the new set up so far all in a bad cross wind one thing that was nice i can fly it 1/2 power and seem to do ok before i always flew full power
the only problem i have now is how do i make it go FASTER HE HE HE
I dont recommend the night lights yet i need to do more tests in the daylight that is
falcon
