RE: Phoenix Model Extra 330 Terrible ARF!
Built the Phoenix 330 2-3 months ago. Same problem with wing tube too long - took less than 5 minutes to cut. Also 3 out of 4 blind nuts came out - ten minutes to fix. Otherwise used all factory hardware and built went quickly overall. Have somewhere between 80-100 flights, great flying plane. Have never built a kit or an ARF that went exactly per manufacturers plans without needing some modification or repair. This was no worse nor better than others including 2 from Hangar 9.
