RCU Forums - View Single Post - What do you think of FORMOST 150 ?
Old 08-14-2008, 05:26 AM
  #618
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Default RE: What do you think of FORMOST 150 ?
Hello Larry,
I took you advice and made the flaps bigger, they are cut to 13" and the ailerons are 10".
That cut worked perfect as it allowed me to slide in a piece of tapered hard balsa aileron stock to make a place for the aileron horn mounting. All I had to do was add a piece of covering to the very end of the surfaces on the ailerons.
On the flaps I had to make a small 1/4" filler out of tapered hard balsa aileron stock to reach the internal rib.
