RE: Sig Lt 40 CG
Just to be on the safe side here are the factory specs for you.
Set Up Specifications English Metric Directions
Elevator 9/16 inch 14 mm Up and Down
Rudder 1 inch 25 mm Right and Left
Ailerons Up 3/8 inch 10 mm
Ailerons Down 3/8 inch 10 mm
Center of Gravity 4 inch 102 mm From the leading edge
Dihedral 3 degrees 3 degrees Per Wing Panel
Incidence + 1-1/2 degree wing, 0 degree stabilizer
Engine Offset 6 degree down, 6 degree right
