RCU Forums - View Single Post - have to return Easy Glider!
Old 08-16-2008 | 09:09 AM
Popriv
Default RE: have to return Easy Glider!
Wrong answer, right results.
When I showed him the crooked tail he said "thats the way they make it, someone else came in and he called the company, its to compensate for the motor" I said I find that hard to believe! I've built many models and the goal is to get everything as straight as you can. when gliding, this setup would have the plane constantly turning left.
I asked if he had another box which he did. I'd feel more comfortable if I saw the same thing on another plane. We opened it up and surprise! the tail was straight as an arrow. we swapped fuselages and I was on my way!!!
I will not go back to this LHS. While he did the right thing in swapping parts this isnt the 1st time I've smelt the BS there.
SO, if he really did have another customer with this problem It would be wise to check this area if you buy a Multiplex easy glider electric...
Alls well that ends well!
I should be flying this afternoon...
Steve
