RCU Forums - View Single Post - Masters Class in AMA pattern.
Old 08-19-2008 | 08:49 PM
KeithB's Avatar
KeithB
Default RE: Masters Class in AMA pattern.
We can "use" the FAI P sequences without making an official AMA rule that says we will, hence forth, always use the FAI P pattern. This will allow us to try if for a couple of cycles and if it doesn't work out we can switch back to creating our own sequences.
Personally I'm somewhat concerned about the shortened length of the P sequences since this would be Masters’ only pattern and it may make separating the top pilots more difficult. However, I'd be willing to try it because I don't think we'll recognize the full benefits, or disadvantages, until trying it for a cycle or two.
As to the rules, I see no reason we should not adopt the FAI rules regarding scoring criteria. Using the scoring criteria would not preclude special rules for specific classes or the inclusion of things that don't apply to FAI such as take-off/landing.
I’ll be happy regardless of which way we go.
Keith B
