RE: Slimline Sport Scale I Muffler O.S. .61 SF & .61 SF ABC,need help
You can drill and tap the muffler and install a pressure fitting. You will need to know what size threads the pressure tap is and then drill and tap the hole with the correct tap. Good Luck, Dave
