RE: MaxCatV1-L Scratch Build
I was away for 2 weeks and just caught up on this thread. The boat looks great Harold.
Marcel, for cutting strakes on the table saw I would set the blade to the angle you wish and set your rip fence so it will just cut the angle on the edge of a wider board, then set the blade back to vertical and set your rip fence so when you run the board thru it will cut the strakes to the size you want. If you try to run little strips like the strakes thru the saw to cut the angles it would be very hard to get them right I believe.
Doug
