Old 08-27-2008, 07:36 AM
bpasternak
bpasternak's Avatar
Default RE: Tru turn prop ?
Hi Erik. What prop are you using? Is it an APC? If so, then you'll need a "wide" Tru Turn indicated with a "W" at the end of the spinner model #. However, it's best to contact Tru Turn with your prop info and they either advise you on a spinner or cut one for you.
I have a 2 1/4" Tru Turn (I forget the exact model # but its not a wide) that you can try if you'd like. However, this still won't fit an APC. Let me know and I'll have it down at the Delaware R/C field for you. I also have a 1/4x28 prop adapter if you need that.
Best,
Brian
