RCU Forums - View Single Post - how to use flex push rods
Old 08-27-2008 | 08:21 PM
JustPlaneSweet
Default RE: how to use flex push rods
I used the tubes provided in the kit and put solid wire 2-56 pushrods through the tubes. The outer tube is glued to the plane and the inner tube is threaded a few turns onto the wire. The inner tube acts like a bearing and takes up all the slop between the wire and the outer tube. The wire holds trim very well.
Stan
