RE: Help Blade CP Pro Problems
Thanks for the input. The blades track in the same plane when viewed from the side, once it's up to speed. It's the mainshaft/rotor hub when viewed from above that can be seen vibrating quite a bit.
I will try adjusting the blade tension and see if it helps.
Tbone
