Old 08-29-2008, 09:11 AM
Rodney
Default RE: Transmitter battery question
Your battery will give you much better life if you charge it overnight on the wall wart which is about 0.1C. I do not know what the quality of the JR batteries are but; in general, NiCad are better for transmitters than NiMh are as they will give you about twice as many charge/discharge cycles and are more immune to minor abuse such as overcharge or deep discharge. Also, most batteries of this type should not be charged at a higher rate than 1C and, if you want long life, not that high. Check out www.rcbatteryclinic.com for some good advice on the care of all types of batteries.
