RCU Forums - View Single Post - 1/4 Scale F4U-1A Don Smith Plans Build
Old 09-01-2008, 08:50 PM
  #579
rack
Default RE: 1/4 Scale F4U-1A Don Smith Plans Build
set your inc 0 deg to the wing if that is what the plan recomends, for datum ref your wing should be set at 0 and the stab at plus 1 deg,never neg that seems to be what you have now , you realy should have the wing on to do this right, get your wing sadel perfect first then set the stab to the wing square it up before glueing any thing use screws to hold the stab in placetill you have it perfect i lock the airplane to the bench with clamps and screws to hold it steadly in place, a slight change in the datum line dosnt mater it can be corected by the engs down thrust
