Thread: Balancing
Old 09-02-2008, 11:00 AM
Clint H
Clint H's Avatar
Default RE: Balancing
You might also take a look at your elevator and make sure it's not warped, or, if you have dual elevator halves, make sure they are moving equally.
Does the plane always roll in the same direction in the loop, or does it randomly roll either left or right?
I friend of mine had this same problem. We tried everything except checking the lateral balance. Finally, when we did check and fix that, it solved the whole problem.
Good luck,
Clint
