RCU Forums - View Single Post - 1/4 Scale F4U-1A Don Smith Plans Build
Old 09-03-2008, 06:55 PM
  #589
rack
Default RE: 1/4 Scale F4U-1A Don Smith Plans Build
your going to confuse your self, you are using a datum line set by don smith, zirole may use a diferent one and royal sumething else, but the main thing is that the stab is set at 0 degs to the wing, or in your case wing 2 degs and the stab two degs wich would leave the eng at 0 giving the eng a true 2 degs down thrust, my airplane is set at 0-0 with the eng set at 1-1/2 down.
just set your stab level to the wing and it will be perfect.
