Old 09-07-2008, 09:49 PM
Campy
Campy's Avatar
Default RE: Where can I find.
I realize this isn't scale, but you do not see the prop when the engine is running.
Can you go to larger wheels and/or longer struts for the ground clearance you need ? It may be less expensive.
GENERAL RULE OF THUMB - when going from a 2 blade to a 3 blade prop - go 1" less in diameter OR 1" less in pitch for equivalent performance. A 3 blade prop is not going to be as efficient as a 2 blade prop.
