ORIGINAL: redsteal92
hi i have a question too, i still have the standard flywheel but with the standard one i cant use a bump start because it's to small do you guys know a bigger one that will fit and start with a bumpstart?[&:]
I'm currently using a kyosho 34mm flywheel. I know that you can use the one from the Hyper 7 buggy. It depends on the starter box too. I was using a dynamite starter box before I went to the ofna truggy starter box. Now I have no issues starting anything. You can also use a flywheel from a Savage X too and its way cheaper!
When using the kyosho or the savage X flywheel I was able to start the truck with my old starter box. Hope this helps.
