RE: 50SX max engine
Typing in all caps is considered shouting.
Once the sleeve is out the rod should slide back and forth a few mm. Sometimes its stuck but with the crankshaft at TDC it should slide enough to pop off the crank pin. You might have to shoot some WD40 up from the bottom.
