Old 09-15-2008, 06:12 AM
Flying freak
Default RE: Wiring a battery for reract servo
You almost have it right but you only have to cut the '+' leave the "-" alone
As far as capacity if you have a smaller battery back laying around it will work you could probably get away with somthing from about 350mah and up Dont forget that you will need another switch between the battery and the y harness
Steven
