RCU Forums - View Single Post - Engine Mounts.
Old 09-22-2008, 02:46 PM
Suprachrgd82
Default RE: Engine Mounts.
The chassis should be slotted to allow the mounts to slide for different size spur gears. Look on the bottom of the chassis.
If I am not mistaken, the centax clutch is longer, and reuires that the engine be mounted further back to allow for this distance. If this is the case, you will need to purchase different mounts, likely a set manufactured specifically for your car. Search eBay or Yahoo or some search engine that will point you to manufacturers.
In the event that no one makes mounts for this application, you'll have to search for another car's mounts that will fit yours.
