RCU Forums - View Single Post - My First Conversion!!
Old 09-22-2008 | 09:40 PM
Jester241's Avatar
Jester241
Default RE: My First Conversion!!
I think for my next build though,I'm gonna lathe out a ring to go around the hub that will lock in place with a set screw or clamping system that will contain the magnet to make it easily adjustable. Your rather kinda limited on the timing adjustment when you permenently mount the magnet into the hub. And if your off by a couple degrees......you cant do much easily to fix it.
