RCU Forums - View Single Post - Question for the Aussie Pilots
Old 09-23-2008 | 09:09 AM
Craig B.
Default RE: Question for the Aussie Pilots
Hi Mattyb
Why don't you give Peter Agnew a call on (03) 9436 2296. I am sure he will point you in the right direction. WRT the gas fittings, I use the powermax cannisters and bought one of the matching gas torches from bunnings. You can take the plastic handle off it, cut the end of the nozzle and drill and tap it for a 4mm festo fitting. You then screw it right on top of the powermax canisters and it is very compact and works perfectly. Peter may have a purpose made fitting that you can buy though.
I run Shell Nautilus two stroke outboard oil (from supercheap auto) in my engines at around 2%. No issues so far and I am alot happier using that for health reasons than the turbine oil that was never designed to be burnt. There is a whole debate available there though that has been done to death on other forums. Each to his own.
Hope that helps.
Craig.
