RE: YS110 fz-s idle issues
well i looked inside the throttle and the barrel moves exactly when the servo dose, after revving up the engine and pulling back the stick to idle the barrel fully close, but yet the engines idle is like 3000 rpms and slowly drops to around 2300 rpms but it takes the engine from 15-35 secs or so, as far as my needle setting, the high is at about 1 1/2, the low is at 1 1/4 and the reg is at 1/2 turn past flush per ys, ys told me to set the reg screw to flush with the body and then screw it in approx half a turn
