Edwin,
These are exactly what I was looking for. Thanks for the tip. The only problem is... I don't know which one of those is for the DA/DL 50 (of those pictured). Do you have one of these? I'd like to see specifically what I'm getting before I buy.
I'll check out the slimline but I suspect you are right as far as it fitting in the cowl completely. I definitely can't dish out $300 for a muffler, but I will certainly experiment with making my own before I give up.
Soarrich, cool muffler. Only problem is the mount. Since it comes out away from the engine so far, I would have to cut away for that.
Russ
