RE: u/c taurus
Hello Stuntflyer.
Your post about this C/L Taurus is interesting.
C/L Stunters usually have the wing closer to the thrust line to turn inside and outside maneuvers with equal turn rates per handle movementl
Because, there is no much difference with my post 15 in “Redesign and reconstruction The Oldest Taurus on Earth”
There is only one configuration for a short nose with vertical mounted motor I think!
Battery beneath the tank and motor/carb level on centre of the fuel tank. See picture 2
So motor in lowest possible position and tank in highest possible position.
When you have to keep room for the radio equipment! Ed must have known that!
Taurussus, still interesting even when “Fly by Wire”!
Cees
