RCU Forums - View Single Post - Plug/Parting board
Old 10-15-2008, 10:17 AM
KC36330
Default RE: Plug/Parting board
ORIGINAL: diggs_74
........I think messing with the modeling clay is a PIA..
i have to disagree. if you get a clay that is hard (not the soft mushy stuff) and roll it out into a thin string form, you can then use a sharpened off dowel rod to pack it into the gap, and use the sharpened edge of the dowel to trim it flush, you can do an entire plug in less time then it takes to mix the bondo.
