RE: Royal Kits
p51fan, I don't think it would be hard to find a kit cutter. You could scan the plans at an architectural supply/service shop. Talk to the kit cutter and confirm any file format required (or send them your plans). I had some plans enlarged at one of these architectural places, and it was quite inexpensive. It really isn't as hard to cut your own as you may think, take an extra set and cut out the templates from the spare plan and attach them to your wood stock with 3m spray contact adhesive (one side only so it can be removed). A jigsaw of course helps, then sand the part down to the template. It won't take as much time as you think, and will give you some satisfaction!
