RE: Problematic location for covering
I lost a stab in flight also. Ever since then I do it the same as you. What has work reasonably well for me is; after using the iron to get the covering down is to go back over it with my heat gun & a heat glove( I modified the flat adapter on my gun to throw out a narrower strip of heat) Mind you you have to keep the heat gun moving, but it will get out the wrinkes.. Good luck.
