RCU Forums - View Single Post - HYPERION EOS 0606i AC/DC
Old 10-26-2008, 11:36 AM
gerardbu
Default RE: HYPERION EOS 0606i AC/DC
Question on 0606i
I just got a hyperion eos 0606i ac/dc
I am charging a e-sky 2 cell lipo 7.4 volts 10c discharge rate 800 mha
The hyperion is set to lipo, c=800mha
When I press to charge the unit say balance con connected
and then a few seconds later says no batterry.
I tried also on dc current on a battery and the same result occurred.
I check for continuity between the hx adapater and the wire to plug to the transmitter and tere seem to be no problem there either
I tried 2 new batteries (never used) as well as the current used and all have the same result.
I am able to charge the batteries withthe cheap charger that came with the heli
what am i doing wrong? please if you can help me I would apreciate it.
