RCU Forums - View Single Post - New 1100 mAh A123 available everywhere and no word here!
Old 10-27-2008, 09:47 PM
  #186
cobrajocky
cobrajocky's Avatar
Default RE: New 1100 mAh A123 available everywhere and no word here!
ORIGINAL: everydayflyer
In that case 3.3 would be the correct setting. A123s settle to approx. 3.45 per cell shortly after charging to 100% capacity.
Charge set at 3.3 then change to 3.6 and note the small mAh capacity added with the higher setting.
Charles
Gotcha on the 3.3v, but at what point do I "change" to 3.6v? And should I choose the max amperage for the charge (5 Amps) or something lower? The "program" for all three types of Lithiums batts allows a longer max charge time of 10 minutes - should I go longer or shorter?
Keith
