RE: SERVOS
It's the digital version of the 225. Most of my racers have that servo. It's a good precise servo. Much better than the 225. Just don't let them stall. Like stall right at the end of travel because of control binding. They self destruct very quickly when that happens and they fail without smoke or warning. When I first suggested the 225 for the Scat Cat I assumed you weren't planning on racing it above the 424 level. The 225 s will serve you well at that level and cost a lot less. The 5245s come with only metal gears but the nylon gears for the 225 will work in it. Some guys replace the metal gears with the nylon gears after the metal gears wear out.
Denis
