RE: 24 Volt Starting
Sometimes 12V is not enough, but 24V seems a bit extreme. I solved it with 18V - three 6V batteries in series. It perks up the starter just enough; on 24V most starters get a little scary.
Charging the 18V battery can be a problem. I use a 6V charger and charge each battery individually. Luck! - Eloy
