RCU Forums - View Single Post - How do you apply Titebond or other Aliphatic glue?
Old 11-02-2008 | 11:30 AM
bigtim
My Feedback: (13)
Default RE: How do you apply Titebond or other Aliphatic glue?
ORIGINAL: Campgems
I use a CA bottle. I picked up a bunch of extra tips and caps a couple years back and I also picked up a 20z bottle. I add about 5 to 10% water to it to thin it out for better penetration. Start with the smaller amount of water and increase if you need to.
Don
I use the CA bottle as well, the tiny aplicator helps with getting into small areas,for glue type I prefer titebond I or II ,the III is a exterior adhesive and doesn't sand as good as the I &II does.
I use titebond for work so I get it in the gallon jug and pour it off into the several different sized containers I need for whatever application applys,large,med, small,and CA bottle.
