RE: How do you apply Titebond or other Aliphatic glue?
Several years ago at a farm supply store, I picked up a syringe and several different tips to for it. These are designed for live stock (and a short life, I am sure), and are pretty cheap. But by cleaning it out (occassionally) mine has kept working just fine over several models built from kits. I like the idea of "storing" the syringe in a water container, though, and have not tried that. I just stick a thin straight pin in the tube and pull back on the plunger to keep things pretty usable. Also, I find that these resin glues are heavy if you over-do their use, but don't think that CA is ultralight either! While the resin glues lose some weight as the water evaporates from them, that smoke you see coming off a tight CA joint is not adhesive departing the model. If you use up a one ounce bottle of CA on your model, you added one ounce of weight to it.
