RCU Forums - View Single Post - Pull start problem
Old 11-03-2008 | 04:46 PM
tsan's Avatar
tsan
Default RE: Pull start problem
ORIGINAL: rotclarry951
Well if you're string broke, just take it apart and tie it back in and then re coil the spring back in which is a pain in you know where. Oh yeah when taking it apart watch out for the killer spring of death!!!!!! meaning the spring pops out sometimes, it scared me the first time I opened the pullstart.
Hi all. It's been 20 years since I raced stuff like electric off roads and 12/th scale onroads, (not to mention I'm only 2 days into the nitro experience)
I'm actually in the process of trying to replace my Tsunami's pull start (string broke on 2nd pull :S), and I'm having a bit of a hard time reaching the forth screw that holds on the assembly. (looking from the back it's the lower-left screw I can't reach)
Is it possible to remove the pull start only, or have I got to remove other stuff before I can properly get access to the assembly?
Thanks!
Tim
