HET Sniper 70mm EDF build
I have been wanting to build this plane for a while and I am excited to finally get going on it. Here is a look at the kit and the components going into it.
Specs:
HET Sniper 70mm EDF
JR 6200 2.4GHz reciever
HET 6904 70mm fan
HET 2W-20 motor
Tsunami 72A ESC
Futaba 3154 digital micro servos
Flight Power 3700mAh 4s 25c battery
The kit itself has very few parts. I was a little shocked not to find any directions for the kit. There is an excelent online manual however. The ESC also didn't come with any instructions. Again there is an online manual on the HET site.
So far the only work done was to clear coat the fuse. It was kinda dull. I also cut out the canopy. It is a little bit small. The dry fit didn't look good at all. I am going to have to do some work there.
