RE: Repairing pocket hinges
You should be able to cut away the covering over the area where it would come out very easily. If it doesn't pull out easily you may need to cut around the tube with a piece of sharpened brass tubing with an ID just larger than the tobe, then it should come out pretty easily.
TF
