ORIGINAL: Mike Emilio
ORIGINAL: Props4ever
I got a bleak hope to get rear fuselage section made from a fellow here in Toronto who has recently resurrected the actual mold for this model and is in process of making 5 fuselages for 5 other exclusive individuals. If all worked out then i don't have make a foam plug to make up for missing section. So for now i started to sand the joint from outside to make it smooth and even with rest of the fuselage. Some of the hanger rash is also being fixed now on the model.
Ok these pictures are for Mike Emilio of Toronto to see the sections required for my model to be made.
EDIT: Guys
Mike has seen these pictures so now i have removed them.
I think I've sent you at least 3 pm's clearly stating that I have not seen whatever pictures you are talking about.
eHmmm ok error on my part again i guess, sorry Mike i'll repost them through site uploading features so you can see them. For some reason your firewalls are blocking seeing pics posted through different server.
