RCU Forums - View Single Post - TBM 93" Zero ARF Build
Old 11-05-2008, 10:28 PM
CHAWKJIM
CHAWKJIM's Avatar
Default RE: TBM 93" Zero ARF Build
Tonight I installed the wing servos, ailerons and flaps. I then fitted the main gear retracts. The cutout needed a little work as you can see from the photos. To do this use a razor blade. This will cut it perfect and the surface is soft enough to use a blade. Tomorrow I will go to the hardware store for the retract socket head bolts . When I finish this I will start on the
ID:	1066453   Click image for larger version
ID:	1066454   Click image for larger version
ID:	1066455   Click image for larger version
