RCU Forums - View Single Post - GST 7.7 hard to turn engine!!
Old 11-07-2008 | 06:32 PM
dar123
Default RE: GST 7.7 hard to turn engine!!
that just sounds like the compression of the engine, soo far it sounds as if you have done everything right. just add a little after run oil (if you don`t have some i`d advise you do) and pull a little bit harder on the cord but make sure you don`t pull it more than 5-6 inches out! good luck
Darren
